Add a Distinct Setting for Allowing Custom List Starting Numbers
This thread[1]. The feature was added, but as per this reply[2], only if the “smart lists” feature is disabled.
I propose splitting this setting, so that one may keep “smart lists” enabled, while still disabling the specific functionality of resetting the starting point of the list.
Essentially:
  • Lists should be allowed to start with an arbitrary number. This number should not be reset to “1” when the list is updated.
  • Other list items should still have their numbers updated as usual when an item is added or removed.
  • The “smart lists” feature and everything else it entails should be kept enabled.
  1. https://forum.obsidian.md/t/add-option-to-disable-numbered-list-automatic-numbering-auto-updating/1141 ↩︎
  2. https://forum.obsidian.md/t/add-option-to-disable-numbered-list-automatic-numbering-auto-updating/1141/22 ↩︎
