Accessing note contents from a plugin?
When going to “properties” tab on the right side panel, I expect there to only be my properties, and not see the default ones like
  • aliases 0
  • cssclasses 0
  • tags 0
Which are not possible to remove (I wrote more about it in this thread: Properties: Unassign type is greyed it, and I can't remove them :( )
  1. Make it possible to remove default properties, if there are 0 usages by right clicking and choosing “Unassign type”
OR
  1. If there are many using them and they are absolutely necessary, as mentioned in the thread here: Properties: Unassign type is greyed it, and I can't remove them :( - #4 by holroy then please improve it by making it possible to hide default properties (a checkbox “Hide default” will be enough"), and possibly explain what the default properties do
    For example I didn’t know alias changes the file description on open file, cssclasses allow you to add custom classes to the file, and tags are part of properties too
Having said, I still don’t think I’ll use these for now, and they feel like they pollute my properties tab now, so I’d like to get rid of them somehow
None :frowning:
You could also having an icon with info and explain the default properties so new people starting with obsidian know what those default properties do as an explainer in a modal window for example. I’m using Obsidian for half a year and didn’t know that
