i play with Publish but don’t use it for real because of the lack of permalinks.
any solution would be good (uuid or slug)
This has been implemented.
Thank you! I read the documentation and noticed this:
If someone visits a note using the original URL, they’ll be automatically redirected to the permalink.
Is it possible to develop this further so that users could also define other urls that will redirect to the note’s permalink
url? Example:
MyNote.md
# My note without a permalink
Url: https://publish.obsidian.md/username/MyNote
Rename MyNote.md
to MyNote2.md
and add a permalink:
MyNote2.md
permalink: 'note'
# My note
https://publish.obsidian.md/username/note
https://publish.obsidian.md/username/MyNote2
redirects to https://publish.obsidian.md/username/note
would also redirect to https://publish.obsidian.md/username/note
? Thank you. Example solution:
permalink: 'note'
alternativeLinks:
- MyNote
# My note
This can be done using aliases.
permalink: note
alias: MyNote
# My note
Multiple nesting levels and other stuff also work:
permalink: note
alias: MyNote, path/to/MyNote, My Fancy Note/With a Twist
# My note
In this case, three URLs will be all redirected to /note
/MyNote
/path/to/MyNote
/My+Fancy+Note/With+a+Twist
Oh, nice! Thanks a lot!
Just a note to myself: Aliases are case-sensitive, so in case of e.g. the MyNote
alias, also the URL needs to contain MyNote
instead of mynote
