Ability to search headers and navigate to headers in a note
For quickly navigating to a header, I find clicking the outline tab in the side panel and scrolling around the outline to find the desired header a little clunky.
I propose a search feature similar to quick switcher, but it only searches for headers inside the currently open note. i.e. Pressing a keybind opens a quick switcher-esque search bar that shows a list of matching headers when you type a query that you can then navigate through and select an item from. This would allow for much quicker searching and navigation between headers.
Just using the basic in-note search function (Ctrl + F). This of course brings up other instances of the text you are searching for besides header titles.
This plugin supports this feature and more:
  • switching between headings in active note.
  • navgating to any note, any heading in any note.
GitHub - darlal/obsidian-switcher-plus: Enhanced Quick Switcher plugin for Obsidian.md
