Platform
[ ] iOS
[x] Android
Currently the vault is saved in plane text in the share folder. I understand, that this is nessesary to offer sync with third pary ( maybe even nessesary for your sync), however this gives all apps access to my partly very private notes. Which is unacceptible. At this point i cant use the mobile app with a good feeling.
Possible Fix / Feature:
Save the Vault in the Aplication storage, where it is protectet by android sandboxing. You can then safe an optional “backup” / sync dummy to the shared file system which can be used by external programs. To make this option usefull, this backup file should be encrypted by a user set password. Idealy in a file based manner, so that only changed files will be synct.
For the desktop app you could add the same feature.
