Hello,
Is there a way with obsidian or an editor like notepad++ or other to delete paragraphs between several titles?
What I would like is to be able to select say 4 titles with their paragraphs, right click and be able to delete the paragraphs directly.
Thanks
This is the kind of operation where vim mode shines. Not sure you wanna go down that road though
Enable Settings > Editor > Folding heading. Then:
- Use the “Fold all” command (find it in the command palette). If this hides the headings you want to delete, click or tap the start of the heading they’re under to unfold it (there’s a triangle you click or tap but it only appears when you touch or hover over it).
- Select the headings you want to delete (select all the way to the end of the ellipsis (…) at the end of the last one.
- Delete. The headings and the content folded under them will be deleted.
