vldiz
May 12, 2023, 8:17pm
1
Hello. I have a trouble with scrolling thing in Obsidian. When i try to copy text line in a middle of document it takes me to the end of the file. So, i don’t know how i can fix it, i can’t edit and copy text. Maybe someone here can help me…
Does it happen in the Sandbox vault? Try these steps and report back if it’s still happening
Troubleshooting Guide
Search before posting
Before opening a new bug report, please try searching the whole forum for duplicates. It really helps us.
Troubleshoot Instructions
In order for us to fix a bug, we need reliable and consistent steps that cause the bug every time.
If something looks wrong, first make sure you are using the latest Obsidian version and that your installer is up-to-date. The app and installer versions don’t need to match, but they shouldn’t be too far apart.
The instal…
vldiz
May 13, 2023, 3:38pm
4
thank you very much for advise to check plugins! It turned out to be very helpful, because the problem was caused by a multi-column markdown plugin.
system
Closed
May 20, 2023, 3:38pm
5
