Continuing the discussion from Can No Longer Differentiate Created vs Uncreated Internal Links (v0.16.2):
Version 0.16 has made created and uncreated links look the same, so I can no longer look at a note and see which links are to pages that don’t yet exist.
I’d like a setting that makes differentiating those 2 link types easier (perhaps fading the uncreated link which is how it appeared in v0.15).
A CSS Snippet solution was provided in the thread linked above. I’ve set mine to match my obsidian accent colour and added a low opacity (which gives me back the v0.15 look), but that will require changing if I change the accent colour or general link colour etc).
Perhaps instead of a snippet, this could be incorporated into themes or appearance settings, where you could just toggle on a setting like: “fade uncreated links.”
