Hello:
Could somebody describe how could you create a note when you are already located in a folder.
Now the only thing i can do is to drop and drag the new note to the folder.
Right-click or control-click the folder and use the contextual menu.
Screenshot of Obsidian (9-22-20, 9-53-46 AM)
You can also use this setting to define where new notes go.
Thanks, Now i should delete this post. QaQ…
