Because obby’s website says it opens plain text files and it doesn’t.
I personally dislike markdown and think markdown is garbage. That’s my problem and no one else’s. But I do think that standard text is just the most powerful and reliable and should be the basis for most operations.
Secondly, asking me to make separate account for the forums is dumb.
problem
obby is misleading users. it literally does not work on plain text.
Obsidian is a Markdown text editor/notebook. That’s what it says on the tin. There’s a FR here to support .txt files natively:
As for the separate accounts, the forum and billing/Sync/Publish/Commercial license accounts should be separate in my mind. Feel free to open a feature request if there isn’t one already.
I bought some peanut butter, but when I opened the jar, all it was was a bunch of peanuts crushed into a fine spreadable paste. So misleading…
Markdown is plain text. And it uses plain text characters to indicate to apps how it can display some formatting. Go ahead and try opening it up it any text editor.
If you are really committed to a .txt file extension in the filename of your files, there is a plugin for that. And if you really don’t like Markdown, there are lots of plain text editors to choose from.
In addition to the other replies, nothing forces you to use Markdown formatting in Obsidian. You can just type a bunch of text without marking any of it as headings, lists, emphasis, etc. The only requirement is the .md filename extension (which as mentioned can be worked around, tho last I knew all of the methods had tradeoffs).
