This bug spawned directly in this version I guess, because on version 1.12.7-3 everything is fine (checked with downgrading)
Install obsidian with latest official AppImage for Linux from obsidian website
Start it
Yes
Obsidian have no errors at startup and working on Wayland
Obsidian starts with error about Wayland and starts in x11 (log below)
./Obsidian-1.13.4.AppImage
2026-08-02 06:57:39 Loaded updated app /home/qwerz/.config/obsidian/obsidian-1.13.4.asar
Fontconfig warning: We will not regenerate the cache because some cache files were generated by a newer version (0x2012001) of Fontconfig. Please regenerate the cache with the latest version of Fontconfig to avoid any unexpected behavior. (current version: 0x2011001)
2026-08-02 06:57:39 Checking for update using Github
[46838:0802/095739.751864:ERROR:ui/ozone/platform/wayland/gpu/wayland_surface_factory.cc:249] ‘–ozone-platform=wayland’ is not compatible with Vulkan. Consider switching to ‘–ozone-platform=x11’ or disabling Vulkan
2026-08-02 06:57:39 Success.
2026-08-02 06:57:39 Latest version is 1.13.4
2026-08-02 06:57:39 App is up to date.
Obsidian version: 1.13.4
Installer version: 1.13.4
Operating system: #1 SMP PREEMPT_DYNAMIC Tue, 28 Jul 2026 13:49:51 +0000 7.1.5-arch1-2
Community theme: Typewriter 2.3.3
Plugins installed: 1
Plugins enabled: 1
1: Remotely Save v0.5.25
Distro Name: Arch Linux
Distro Version: rolling
Desktop Environment: latest KDE
Installation method used: Appimage
On version 1.12.7-3 everything is fine (checked with downgrading)
I don’t think that there is a specific problems on my system. It’s clean install of Arch
Version 1.12.7.-3 is from Arch repos.
Anyway if I install 2 versions of obsidian (on screenshot) from GitHub the brand new one (1.13.14) have this problem and the old one (1.12.7) don’t.
I can try installing a WM with Ubuntu or whatever but I’m sure that update broke something no matter what system is.
if that helps, obsidian 1.13.4 on wayland on nixos works fine. can it be a problem with your installation method? can you try to install obsidian from the official repository via a command like sudo pacman -S obsidian? they have already updated the package
it may be a problem with electron. did you update the system? maybe the wrapper for obsidian cannot find electron 43 or electron binary in the system is malfunctioning.
The only installation methods we support are the ones on our website. Please, do not complicate things with unauthorized/unsupported third-party redistribution.
Again, the icon is a different problem.
I don’t know if you have any actual problem.
The error that you see about wayland and vulkan is a longstanding chromium support problem and it being worked on upstream.
